smokinpipes
Navistar Nut
Hello all, long time reader, first time writer... and this seemed to be the place I should ask upon fellow Ford fans (or knowlegable ones aswell )
I have an '85 F250 with the 6.9L diesel, I just changed my air filter, replaced the injectors, the o-rings, the caps, and lines, checked everything for fuel leaks, but I'm only getting 12.5 mpg on average. Sometimes 13!!! Now being my third 6.9l diesel truck, it seems low compared to my other two. It does have an automatic, but so did one of my other ones. My first truck was an extrended cab 2wd, with a 6.9l, and auto and that got 15-17mpg, then my second was a 250 2wd, manual, standard cab, and that got 15-20 mpg,
Now my latest one is only getting this? Any ideas? It does have a subtle miss when it's cold (all glow plugs work) and blows out the occasional blue smoke puff right after it misses. It has only 97,000 on it.
Next question...same truck, but it shifts hard going into second gear, the harder I press the throttle, the longer the engine revvs and then just slams into gear, if I'm light on the throttle, it shift smoothly. I adjusted the throttle vacuum valve, and made sure the kickdown rod wasn't misaligned... Again, ideas?
Then the last one, I did a head job on my 85 with the manual trans, got it put back together, started it up, and ran for about 10 seconds, just long enough to start to build oil pressure, (changed the oil too) and then something broke on the #1 cylinder and bent the exhaust valve pushrod, and stopped the engine dead flat. took the glow plugs out, and cranked the engine over with a ratchet and found no air moving in or out of the glow plug hole. Now I suspect I broke a writst pin, or a connecting rod, but why? It has only 160,*** miles on it. The head gasket was leaking antifreeze from the front of the block, but I wasn't burning any coolant, and when I looked at the original solid steel gasket, it showed no signes of compressioin loss, and the hone marks were still very visable on the cylinder walls, so the piston wasn't scraping... do you think is might be possible to salvage something out of the eninge/block or am I screwed. Yet once again, any ideas?
Thanks to you all for your thoughts and advice
-Don
BTW, I photographed my cylinders with my camera to "document" the job if itmay help.
-Don
