This does not sound good....
F350camper
BOOST!
yeah, spinning way to slow, if its not the batteries its the starter, or maybe even the cables
ps444mike
Southern Calif
better batteries not sure where you jumping from another truck ? is it running.. maybe raise the rpm on that truck.. battery cables good down to starter..
Cruiseomatic
Defining Insanity
Dark side of the Sun.
2X Motorcraft MAX 850 CCA and both are good. Pulled them out of my 2004 6.0 which they spin over just fine. But it sounds like I've got either a dead skip on 2 cylinders or something isn't right. Its not the GPs. I tested each one before I reinstalled them. And the very ragged out jumper cables aren't connected but the truck does need new cables to both ground and starter.
Hydro-idi
Lodi, California
Looks like you answered your own question. If you have crumby battery cables, this can and will cause slow cranking even with fresh batteries. I would replace cables and go from there. If symptoms aren't fixed, I would point to starter. Your engine is not cranking fast enough to light er off.
Cruiseomatic
Defining Insanity
Lol, I'm not asking why shes not starting. I know why, But, the way shes turning over. Hard,hard,hard,hard,easy,easy,hard,etc... Is it me, Or, Is there a loss of compression? I don't have a reliable compression gauge to check. Lost alot of my tools in the divorce...:mad: I don't expect her to start at all. Still need fuel pump, fuel lines, air cleaner assy,etc... Trying to get a baseline whether or not this either A) engine is shot B) truck is worth the trouble and expense. Or, Could the lack of speed cause false symptoms? Like I said in a previous post, I'm not terribly familiar with IDIs. But thanks for the suggestions guys.
without a compression/ leakdown test theres no way of knowing until she lights off.
i hear what your talking about on the hesitant rotation, but until you light her off, warm her up youre chasing your tail.
Waystro
No Class
South Texas
If your battery's are good then check cables. I've spent many a time trying to crank my old 6.9(not the one in sig) with crappy cables pretty much is like the video it'll start eventually but your just going to cook the starter and drain your Batts. I replaced just the clamps it made a huge difference replaced cables to then she felt like a new truck. ;Sweet
Group 31 Anyone? :angel::D
It sounds like ***** batteries a worn tfo starter and keep doing that n u be making smoke soon
New batteries and if you can group 31 stud tops not lug tops
Starter is cooked dude.
Thoroughly inspect your cables and replace if needed.
Clean block where grounds attach too.
If cables are swollen or have corrosion they need to be replaced with new ones. Or purchase material and buld new ones. I did a thread on building new cables.
Is that some kinda booster pack there with LED on it.
JM2CW
BrandonBerkosky
Dickson city pa
Mine was doing the same. I couldnt crank it fast enough to bleed injectors.
So I dragged it down the road in gear and they bled. Lol. Turns over like a rocket now.
HS108
Diesel Newb
Connecticut
I think your hearing things..
You need new cables, its spinning slow and sounds like that because the starter is struggling.
Replace your cables and clean up the grounds where they attach to the truck
Runningaford
Id/Az
I didn't hear it turn over for that long, but it sounded for the most part like they sound.
ntjapkes
