seawalkersee
It needs a turbo...
My IDI running with video in a Bronco
Well...I picked up my 6.9 yesterday. The 351 actually got great gas milage for being in a Bronco with 33s and stock 3.55 gears (between 11 and 14 depending on how hard I hammered it) and had enough power to speed up no matter what size hill or what gear.
Anyway, I need the engine to put in another car and found this IDI for a song. I will be welding in a patch panel on the subframe so I can mount the engine in the Bronco. I have a few qestions though...
For the fuel, how/what is the best way to do the lilft pump? What I mean is, some people have the Holley pumps and others of the sort. Do you also use the lift pump to get to the IP or does the electric pump eliminate it totally?
Unfortunately, I was not able to be there when the pulled the engine out so I did not get to see how the fuel line went from the drivers side to the passenger side...Can someone post a pic of that?
Bypass filters (I have been trying to do research for a few months so I make as few mistakes as possible) what and why?
Since the vehicle has a new "GAS" tank with no baffles in it, and the pick up is just a screen, I will want to put a large filter in front of the electric pump to keep from cavitating at lower levels though this should not be a problem as I will have to keep it 1/2 or better when wheeling. Sound right?
Chris
Chris
