mrbrink
About a week ago, right as it got cold around here, my glow plugs gave out. before, once I was able to get it running, it wouldn't give me any problems other than a little smoke and the occasional hiccup for the first few seconds. Now with the new glow plugs, it fires right up cold but will start surging, and has even died on me a couple times. at the peak of the surging it idles around 900-1000 rpm's cold with no advance, normally it idles around 600-750. Once its warm, it'll fire right up and run perfectly.
Another thing that I found while trying to run down a ticking noise, when I crack the injector line to the rear cylinder on the passenger side, there isn't much of an audible change compared to the others. Could a bad injector cause the surging issue possibly? Until it warms up, it rolls smoke too. The pump hasn't been touched and it smokes pretty good normally, but when its cold it really rolls no matter how I drive it. Fuel filter has less than 1000 miles, new air filter last week.
Does anyone have any thoughts on this?
Thank you
Thank you
