'94IDITurbo7.3
HAMMER DOWN!
i emailed ARP about the torque the nuts then back off and retorque multiple times b/c i have heard to do that numerous times but never really understood the need to do that even though it has been explained......
Eric,
if using the ultra torque lubricant it is not necessary to cycle or re-torque the nuts. However (if being used as head studs) the head gasket manufacturer might recommend specific re-torque instructions as the re-torque at this point is to compensate for the compression of the gasket and does not have anything to do with the pre load on the fastener.
Regards, Zac Kimball
Automotive Racing Products
(805) 339-2200 ext. 206
basically, the only need for doing this would be if the OEM calls for it to properly squish the HG if you will. doing this will have no effect on the studs.
