stuck fuel filter.
notenuftime
Pennsylvania
Need to remove my fuel filter to get at my injectors, i can't get it to loosen up with my filter wrench. Any one got suggestion of how to get this thing loose, thought about just pounding it off with a hammer and screw driver and just get another.
Waystro
No Class
South Texas
This is why they should only be hand tight.
As far as getting it off poke a Screwdriver through it and give it a couple hits with a hammer and it should Come loose.
Had to do this on a oil filter.
larson
Springtown,texas
I have had fuel filters leak on me until i snuged it up tight with a filter wrench. My point being some times hand tight isn't enough but just a little more and it seals tight. With that being said I never had one I couldn't get off either and hand tightness does very.
The above post method does work have had to do the same thing to an oil filter. A chain wrench works too but id hate to beat up the filter head like that.
The proper way to install any filter that has an O'ring, flat rubber gasket or a tapered rubber seal, is to ALWAYS Oil the seal, then when the seal touches the sealing surface, another 3/4 to one turn is sufficient. That makes removal easy with a filter wrench. The trick to remove a stuck filter is to put a piece of sand paper under the wrench band, doubling it back so sand is on both side's, doing that, it makes the band a little tighter and grip.
Sandpaper grit is your choice, but 60 or 80 grit works best.
larson
Springtown,texas
Yes what ever you do please oil the seal ring always.
Thats a great idea with the sand paper.
Wvdirtroad
Wv
Well if the filter wrench you're referring to is a rubber strap wrench, the only way you'll get it off is if you punch a hole in it and spin it off. If you don't have a rubber strap wrench a vacuum pump belt flipped inside out works good. Also, I know it sounds silly but make sure you're turning the right way.. Sometimes I get confused and have to think about it!
Get a pipe strap wrench from horrible freight. They are cheap and will work well for what you need. But as already posted. Oil the seal and 3/4 turn after the gasket touches.
There are all kinds of filter wrenches, I assumed he has a steel band swivel handle that tightens the band on the filter, like the first HF link, there is actually two sizes of them. Hell, a quarter stick of dynamite will get it off too. :D
http://www.harborfreight.com/3-34-in-oil-filter-swivel-handle-wrench-68963.html
http://www.harborfreight.com/4-piece-end-cap-oil-filter-wrenches-94096.html
http://www.harborfreight.com/universal-3-jaw-adjustable-oil-filter-wrench-69021.html
http://www.harborfreight.com/locking-oil-filter-wrench-66570.html
fsmyth
conroe, tx
I have had very good luck with the special pliers made for that.
There are 2 sizes - one for the normal fuel/oil filters and one for
the bigger ones on the medium/heavy trucks/tractors.
A lot faster, if you have the room to use them. The little teeth
grip even a housing someone crushed trying to get it off.
PwrSmoke
Northwest Ohio
I second the strap wrench. Had one for 30 years. Used it maybe a dozen times over that period but when I did, it was the only thing that would work. If you use the strap wrench and place the strap up near the base, you have half a chance to get the filter off without crushing it.
junk
Paullina, IA
I use a strap wrench that's made out of seat belt style material. Works great on oil filters and fuel filters.
Lance
