Well I fixed the play in my wheel and took a pic of whats wrong. The repair is simple but reaching in is terrible. The shaft needs to be removed by taking out the bolt at the firewall and sliding the shaft down to the gear box. Then pull it up and out. then you will see the stub shaft from the rag joint has the broken flat spring and the plastic holder. Thats tuff to remove because the plastic fits so tightly. Anyway once it of clean it and reinstall the flat spring and plastic holder anyway that works for you. Remember its a tuff place to reach. Lube it and slide the steering shaft back on that stub shaft and then push it up to the firewall shaft. That firewall connection can only be made one way too so there is no problem with messing it up. Thats about it..
