My steering wheel has some play in it. I found the joint where the colume to the gear fits to have some slack in it. Is there a way to tighten it up or am I out of luck. The rag joint is solid and the universal joint is fine. Its just the coupler joint thats loose...
But I got it apart. Found the spring broken causing all the slop. About 1 1/4 inch at the steering wheel....
