leswhitt
What's the breakdown of your mix meaning how much motor oil, atf, hydraulic fluid, kerosene, rug, and diesel do you have mixed in?
It's roughly 40% atf,30%,20% rug and 10% diesel.
I'm running on pure diesel now though, from the front tank that has never had anything but diesel in it.
I bought a new lift pump today. I live put of town so I have to plan ahead. I'll test my pump when I get home and replace it if need be. It's made by " Precision Pumps" I wanted a Carter but as long as it wasn't an airtex I was happy.
Do you have a Lowe's or Home Depot near you? They'll have an adapter in the plumbing section (close to the black pipe) to take it from 2" to 1.5" and it won't cost you an arm and a leg, probably only around $5. As for hose, I use a green hose from Tractor Supply that cost me $29. It's 20 ft long, decently flexible, and will do the trick. I run identical hoses for input/output and don't have any issues using them. The same hose can be found on Amazon, IIRC it was $44 but that was with cam-lock fittings instead of the simple screw-ons. But yeah, your pump will work 10X better than the other pumps you listed and has a smaller footprint than a super sucker (although those are awesome).
**EDIT** I just looked up my hose and it's Tigerflex too...I guess the 1.5" must be a lot easier to handle than the 2". Either that or I'm just awesomely strong![]()
With 20% RUG and 10% diesel you should be good to go, I'm with you on thinking that the lift pump might be going out. I went through a couple when I started running WMO on my IDI, the warranty made it easy to keep swapping them out though.
What brand pump did you get? Why do you think you went through more than one? Is it common to get bad pumps?
I don't know if it's a common issue or just bad luck but I went through 2 pumps in about 4500 miles before finally getting a good one that's still ticking. This was way before I was measuring viscosity and even at a lowly 6.5psi, these pumps seem to be affected by thicker than normal fuel. Once you get a good one it doesn't matter as much but I was 1 for 3 on finding a good one.
I *think* the brand was airtex, it's the cheapest one from Autozone and they warrantied them both witho no questions asked.
. Did the oil that you ran with possibly emulsified water in it foam pretty bad? I was using my PS pump to pump it into my filtration barrel and it is foaming pretty bad. Is that a sign of water? None of my other wmo foamed.
