93idisv2007
and whats the diffrence between the turbo injectors and non turbo ones can i run turbo injectors in my n/a and do the give a little more power?
Hopefully the member thats doing this testing will have something to post about whats been found out... I know I'm waiting and watching for this...
so are you saying no matter the injectors i put in are't gonna make much a diffrence on a n/a or should i stick to the orginal ones?
Most original injectors are no longe made. Kenny has found someone that is able to "fix" his oem injectors but thats not the norm. Sometimes I find a seller or two on ebay selling some E codes but its not very often. About all thats available now is Bb og G codes. A g code will not help a non turbo engine run any better but it will fix a bad any code injector. If you injectors now are in terrible shape then the answer is yes.. A g Code will improve how your engine is running. For an na engine is recommend a set of new Bb codes.
