Injector stuck in head
miked
Bruce County Ontario Canada
Hello
I am pretty sure I know what I have to do to fix this, but thought I would run it by the more knowledgeable people on here.
I was removing my injectors and 7 came out just fine. But one I could feel just brake loose, than as I tried to turn it farther started to tighten up.
I tried turning it back and it stayed tight. Tried to loosen it again and it got tighter.
Total movement about 1/8 turn.
Pretty sure the threads are gauled and decided not to worsen the issue by forcing the injector farther and totally ruining the threads in the head.
Now I have to pull the head and machine the injector out of it, if I want to save the head.
Thankfuly I have I the equipment to do that. Just have to familiarize myself with the injector internals, to decide the best way to proceed.
This post is a hail Mary in case someone has had this happen and has a simpler solution.
Black dawg
sw mt
If it can still be run, fill those injector threads with atf and warm the engine up. Rock the injector back and forth. Have never had one I couldnt get out. Always a first time though....
miked
Thanks black dawg
You give me abit of hope. Any bits of advice is always welcome.
Fueling system is removed so i can't run the truck.
I have applied atf and penetating oil and am leaving it over night.
May apply a little heat tomorrow.
If I had to guess, it took about 40 to 50 foot pounds to break the injector loose.
I figure I was up around 120 to 140 foot pounds when I decided to stop because it was acting like a thead gauling to me.
Getting tighter no matter which direction I applied force.
And for fear of making things worse.
As a machinest i have seen what happens when a gauled fastener is forced to far. The less you move it the better the chance of saving the important parts.
ihc1470
Idaho
If you have the room you might try an impact wrench set low enough not to move it but to just jar it and hopefully get the atf and penetrating oil to move down. Half acatone and atf makes a good mix also.
ROCK HARVEY
Dayton OH
This is actually very common! My bet is that it’s not galling, but carbon buildup that has made its way past the copper washer and into the threads. If you keep trying to back it out you will end up unscrewing the top half of the injector body and the lower half will be stuck in the head. Here’s the video that saved me when that happened to me:
If it was me, I would soak it in something that eats carbon, like PB blaster, then keep trying to back it out.
BeastMaster
Orange, California
I don't know if anyone has ever done this...but I will run it up the pole for comments.,
Liquid Nitrogen. Hospitals often have some.
Styrofoam cups will hold it. If you can fashion a plastic pill bottle so as to contain some liquid nitrogen ( LN2 ) around the injector. Seal around the bottom with chewing gum. All you wanna do is keep the liquid nitrogen bathing the injector and not on the block. Maybe something like wheel grease to keep the LN2 off the engine block. You just want a really cold injector for a few seconds to make it shrink. Pour in some LN2 then see if it will break free.
I speak theoretically. I have never done it this way. I am only aware that temperature gradients sometimes help things come apart, and heat makes the thing get bigger, so maybe cold will shrink it.
I may be full of crap. Someone here may have tried this to no avail. If I am full of crap, let me know so I can delete my comment. The posts above mine are far more practical.
miked
Liquid nitrogen would probably work. We had a customer that made liquid nitrogen and let us pick some up when ever we wanted to. Have installed and removed press fit components more than a few times with it.
I don't have access to this company any more.
Also have used dry ice which some welding supply companies carry.
Thanks to Black dawg I am now more educated in these engines.
I applied some heat with a propane torch and sprayed it with oil and then used ihc 1470 impact wrench suggestion.
When I tried pulling on the injector I found i could get some more movement out of it. And the pressure seemed to ease off a bit. Then I resprayed it oil and plan to let it soak again and do the same the next day. I now belive this will work and no longer belive the threads are damaged.
Beastmaster I like the cooling idea I would use dry ice because it is easier to get and use. though not as cold as liquid nitrogen.
I would get a can cut a hole to slip over the injector, simular to what you suggested, put a socket on the injector then fill the can with dry ice and let it sit for awhile.
Then while pulling on the injector apply some gentile heat to the head and see if things start to move.
I have used this in other applications sometimes with success sometimes not.
Black dawg
sw mt
The rocking it back and forth is key.
Also leave the injector where it feels loosest so that oil can seep easier.
BeastMaster
Orange, California
I know the LN2 is kinda impractical unless you know someone who makes it or uses it. As you know, it doesn't keep well. But, being a liquid, it pours well and cools anything dipped in it almost instantaneously.
The intention is to cool ( and shrink ) the injector before the surrounding head iron. Hopefully freeing it enough to get it out with the wrench. The LN2 containment only has to live long enough to free the injector, then leave nothing behind that can't be wiped up and tossed. It may be tricky getting solid CO2 to transfer heat fast enough, as CO2 is a liquid only at a high pressure. A can of freon might do it.
I have heard others in the aerospace industry speak of this, however I have never done it. I did watch a friend install some press-fit bearings using heat. I learn the weirdest things in a shop, usually when I am supposed to be doing something else! I'm kinda stubborn on this-as I consider knowing what one is doing is more important than doing it, cause if it ain't done right, it's gonna be real expensive to back out of the mess I just made.
The good news is that there won't be anything to clean up after using either one of these methods. I'm very interested in hearing the results of this experiment.
Rocknit4x4
Indiana
Pretty sure moose diesel sells a tool to remove the stuck injector for $50 or so.
miked
I took a look at the tool on the moose diesel web site. it works basically the same way as the video Rock harvey posted.
Which my thanks for posting that video.
I did finaly manage to unscrew the injector out of the head and of course it unscrewed from tip. So I turned off the threads in my lathe screwed it back into the tip thinking a little wiggling would break it loose.
Nope,
it is still fighting me. I tried to rotate with a wrench to the point I feared I was going to strip the threads. I thought I got it to start moving side to side but I believe that the thin wall of the bottom section that the top screws into is bell mouthing instead.
I can't attach a slide hammer to it as it is the back injector on the driver's side under the firewall. So I ground a prybar to fit under the hex better and tried to wiggle and pry at the same time. Not moving yet.
I have it soaking for the night. Hopefully I have better luck tomorrow. I may have to come up with some tooling that will allow me to jack it out
BeastMaster
Orange, California
I have queried ChatGPT on this and post here what it replied. This is AI stuff,
New
Is there exist a wrench for stuck bolt removal that is assisted by ultrasonic vibration, similar to an impact wrench?
GPT-5 mini
Yes — tools and devices that use ultrasonic vibration to help remove stuck fasteners do exist, though they’re niche compared with mechanical impact wrenches. Two main approaches you’ll find:
Ultrasonic-assisted hand tools / drivers: These are handheld drivers or inserts that transmit high-frequency, low-amplitude vibration into the fastener to reduce static friction and break corrosion/seizure. They’re used in precision assembly, electronics repair, and some specialty maintenance tasks. The vibration helps “unstick” seized threads without high torque shocks.
Ultrasonic nut/bolt loosening systems: Industrial/maintenance vendors sell bench or portable ultrasonic transducers with adapted sockets or collars that clamp to a nut/bolt and apply ultrasonic vibration (often via a horn/sonotrode). These systems are commonly used for stuck pipe fittings, corroded bolts in aerospace/automotive maintenance, and in manufacturing to aid disassembly.
How they compare to impact wrenches
Mechanism: Ultrasonics reduce static friction and break rust at the interface via high-frequency oscillation; impact wrenches deliver large impulsive torque to overcome torque resistance. Ultrasonics are less about adding torque and more about freeing seized surfaces.
Use cases: Ultrasonics work well for corroded/stuck threads, frozen fittings, delicate assemblies where you want to avoid heavy shocks. Impact wrenches are better when you simply need high torque (e.g., large wheel nuts).
Limits: Ultrasonic devices typically won’t remove a bolt if the shank is shear-failed, heavily rounded, or requires much more torque than the tool’s coupling can supply. They also require contact coupling and sometimes special sockets/adapters.
Where to find them
Search for terms: “ultrasonic bolt loosening,” “ultrasonic nut loosening tool,” “sonotrode bolt remover,” or “ultrasonic anti-seize tool.”
Suppliers: Industrial ultrasonic equipment manufacturers (e.g., companies that make ultrasonic cleaners and welders) sometimes offer bolt/nut loosening attachments. Specialty maintenance tool suppliers and aerospace/ship-repair vendors may stock them.
Practical recommendation
For routine automotive or workshop use, an impact wrench plus penetrating oil and heat is usually more practical and cheaper.
If you deal often with corroded/stuck fittings, or need a non-shock method (delicate structures, bonded assemblies), consider contacting an industrial ultrasonic-equipment supplier to evaluate a sonotrode + socket solution for your bolt sizes.
If you want, tell me the typical bolt sizes and application (automotive, marine, industrial, electronics) and I’ll search for specific products or vendors.
Removal of fuel injectors in Ford (IH 7.3L IDI ) diesel engine
GPT-5 mini
For removing stuck fuel injector hold-down bolts on a Ford IH 7.3L IDI diesel, use proven mechanical methods rather than ultrasonic—they’re more practical, available, and effective in that application.
Quick, actionable steps
Prepare and protect
Battery: Disconnect negative terminal.
Clean: Remove dirt/debris around injectors with compressed air to avoid contamination.
Penetrant: Apply a quality penetrating oil (PB Blaster, Kroil, or Liquid Wrench) around the bolt base and threads; let soak 15–30 minutes (longer if heavily corroded).
Use correct tools and technique
Correct socket: Use a short, high-quality 3/8" drive 10 mm or 11 mm (verify exact size for your injector clamp bolt) impact-rated socket—avoid cheapo Allen/hex sockets that round heads.
**Torque/impact driver:** Use an air or battery impact wrench (1/2" drive for higher torque if space allows) or a hand-impact driver if access is tight. Impacts break corrosion more effectively than steady torque.
Breaker bar first: If using hand tools, apply steady torque with a breaker bar before trying impact—heat is next if it doesn’t budge.
Heat and protect surrounding parts
Heat: If bolt won’t move, apply localized heat to the clamp area with a propane torch (not oxy-acetylene). Heat expands metal and breaks corrosion. Protect fuel lines, seals, plastic parts, and injectors with heat shields or a wet rag.
Reapply penetrant after heating and let cool a bit, then try again with impact.
Vibration/hammer technique
Punch and tap: Lightly tap the head with a ball-peen hammer while attempting to turn—vibration plus impact-style turning can break corrosion. Use care to avoid damaging the injector or seat.
Last-resort extraction
Drill/left-hand drill bits: If the head rounds or the bolt shears, drill center and use extractor (easy-out) sized to bolt. Support the injector to avoid pulling it into the head.
Seat inspection: If the injector or bore is damaged, be prepared to replace injector sleeves or have a machine shop repair the head.
Reassembly best practices
Clean threads and holes thoroughly.
Anti-seize: Apply a thin layer of high-temp anti-seize to new/reused bolts (or use new bolts).
Torque to spec: Torque hold-down bolts to Ford spec for the IH 7.3L IDI injector clamps.
Specific notes for IH 7.3L IDI injectors
Injector clamp bolts are often steel into cast iron head and can seize from heat cycles and carbon. They’re accessible from top but often recessed—short impact sockets and universal joints can help.
Many technicians replace hold-down bolts with new OEM bolts during injector service because of common corrosion.
If you want, tell me whether bolts are just tight, rounded, or already broken off and I’ll give a tailored extraction sequence and suggested tool list.
AI may display inaccurate or offensive information.
Back to me - I post this with intent it might offer something useful.
Black dawg
sw mt
Like you said, probably have to build something.
Sucks when you get to the point....time wise....that you start wondering if just pulling the head would have been quicker/easier.
