XOLATEM
Virginia... in the brambles
Not entirely necessary to pull the engine out, but took less than 3 hours. Having done so will make everything much easier to work on…
Did this yesterday.
Shop is very very messy…
Judging by the blown-over tool box...this is what I imagine musta taken place in that cool shop of yours...
XOLATEM
Fighting the good fight against cabin (global) warming....
Does Ol’ One Ton have A/C or was it never equipped?
Never equipped...
I feel...vicariously vindicated viciously victimizing vociferousity...
Uhm… good for you LOL :dunno
I had to clear up some grogginess before I could get into gear...
cupholders…
Indeed
Yep...gotta not let it fade into obscurity...
Now that we got that outta the way...Happy Monday Y'all...
And to you as well
Thank you very much...I'll try to make the most out of it...
Speaking of the good fight...Last week I finally got the chance to use 'Ol One-Ton to help someone out...actually it's first service call while I have had it.
Glad to hear it! That’s always kinda fun. I’ve gotten to do it a couple of times now, last weekend on a 605J Vermeer round baler, the guy bought it non operational and it needed a new drive chain, and the PTO gearbox seals replaced. Took most the morning, took my 91 F-Super Duty service truck
Ain't it a wonderful feeling to be prepared and to execute a plan...?
Other than using it for my own purposes...I actually went somewhere with my truck and fixed something for someone else...
:Thumbs Up
Thanks again...
I felt good...charged even...I had the old, 'sense-of-purpose' feeling while I was engaged in the activity...and actually using my truck for something other than building a house...
It started last year when an older gentleman called me and said that they needed to get their truck running and moved...
It is a 1965 Ford two-ton dump truck that he had used when he had a roofing business...grand old thing...was powered by an FE gas engine and four-speed.
I had seen the truck before...so I did not ask what it was...I just needed to know how long it had been sitting...
'Two to three years'...came the reply...I told him to see if the battery will take a charge first...and then call me...
Secretly...I knew that it was a good chance that the gas had soured in the tank...but...first things first...
Fast forward one year...I get a voicemail that had a lot of stress in it...on a Friday afternoon...that he needed to move the thing by Monday morning...
I sprang into action...the message was already three hours old...I uncoupled my truck from everything attaching it to the jobsite..extension cords, air lines, radio and makeshift antenna, nuts, bolts, screws, washers, a can of welding rod stubs, buckets, scrap metal, tools, etc.,etc....you would not believe what can pile up around your truck when it becomes a stationary work site...
Finally I cranked her up after checking the oil and charging system and headed down the driveway...I took note of how many miles was on the odometer as I chugged down the road...
I called the guy and said I was on the way...
Thirty miles later I am there...and the field...I am not ******** you...the grass was waist high...I groaned to myself and just 'knew' that The Girl was going to have to inspect me for ticks, later...
Tick, chiggers, maybe snakes...(Both kinds...)...Oh, well...here goes...
So...He didn't say much about the grass...and he rolled up with a battery in a loader bucket and was surprised that I was there after only one voicemail...membership has it's privileges...
I opened the hood and took off the air cleaner...Autolite two-barrel...cool, simple...I put gas in it with a can and a hose while he goes to put his battery in under the passenger floorboard...he borrows a socket while I take the fuel line off the mechanical fuel pump...I drain it into a pan...and it comes out stinky and yellow....
My 63 was a four barrel, 292 Y-block. Very finicky…
(Y-blocks are cool...external oil pump...at least the 312 I saw had one...)
The 330 in my 65 was a two barrel, much simpler yes
(I built a lot of motorcraft 2-bbls over the years...)
Oh, boy...well..gotta deal with it...
The rubber hose has been taken off before...and it was too short to go back on...and the fuel ran out pretty fast...so I cinched it off with some vise grips and looked through my stuff for another hose...
Found one...but it was going to be a struggle to get it up on the barb...I find that the hose clamps are ok...but judging by how fast the gas came out...the tank was close to full...
But...once the initial burst of yellow gas came out...it started running white...so...there was a chance that the gas was going to be ok...
I crawl underneath with all of the high grass and pull the old line off and while I am forcing the hose on the barb I get soaked...I mean really drenched with gasoline...my t-shirt was soaked...(feel the burn)...
I get it back together and it RUNS...runs and then idles...
Good, old truck...
We let it run for awhile and then he says that the real test is if it will shut off and then re-start...it did...no problem...
I pack up...put everything away...and get ready to leave...he asked me about payment...I refused...I figured that it will come back to me, somehow...and I saved the guy from agonizing all weekend about moving the truck...
Sometimes...peace of mind is priceless....
Was it an F-Series or an N-Series?
(I don't know...all I saw was a cool old body and a dump bed that works and what the guy said was 1800 bucks worth of tires...)
Thanks for the interest and feedback...
Yesterday I did the most "I don't wanna" thing I have done in awhile. My brain thought it was absurd but, the machinist said to do, I power washed my freshly machined motor block with Dawn in the soap despenser.
No. That's absolutely what you want to do. It helps to get rid of the left over machine oil and helps to remove any left over metal shavings/chips that may still be there from the machining process. I hope you put something in the cylinders afterward to help keep rust out. U spray some WD-40 on a rag and wipe the insides of the cylinders with it. Right before I install the pistons, I then use some carb cleaner (or something similar) on another, white rag, cloth, paper towel, etc. and wipe the cylinders until the rag comes out still white. Then I inspect the cylinders to make sure that there's no pieces of the rag left inside them.
I did put the orange lock tite on the bolt for my peace of mind.
Always a good idea.
I thought that was R&D? Maybe not though…
You're right.
tbowker
Hudson, Florida
That was some excellent word-smithing
Ha ha, funny you should put it that way. Decades ago, I was working at a nuke, and at the end of the shift we were required to write a job log of what was done so that the incoming shift could pick up where we left off. I had some long winded, comical diatribes and was eventually labeled as a word smith.
most of my books are packed away from the move
Well sir, if that previous tale was you shooting from the hip, I'll wait with bated breath for the unpacking.
XOLATEM
All that gasoline and you were still covered with ticks and chiggars?
From the waist down...you oughta see...no, wait...you don't want to see all of the places that I have scratched the last few days...
Some of those dame with an optional centrifugal supercharger in the Thunderbirds in the late 50's. Boy I sure would like to look at one of those!
I built a transmission for a Studebaker that had one of those in it...
Darn thing was fast...for how heavy it was...
Only seen a couple of those over the years...
Cant Write
Placerville CO
KansasIDI
I hate printers
Wilsey, KS
@KansasIDI i was wondering if I dare ask about the tool box on its back!! Glad you did it @XOLATEM
I’ve been mad before and my boot has upsided things of that nature!! 3 hours, you work fast!!
The toolbox got knocked over in a gentler manner than it seems was imagined, not surprised that y’all thought it stemmed from frustration. Some things do. All good though.
KansasIDI
I hate printers
Wilsey, KS
It was actually fairly peaceful as far as engine pulling goes, I never really got aggravated like I do sometimes. Looking back, the toolbox on its side was actually a different incident altogether, not even the same day…
DougBoy66
Cass County Missouri
Always a good idea.
You're right.
I did exactly that. I blast it with air and rotisserie'd it until I was sure the water was gone then copious amounts WD-40 on everything. By the way a tarp covered in Dawn soap water and WD is very slippery if not paying attention
1mouse3
il
Air cooled engine, need to pull shrouds off and clean cylinders and heads of debris if it has been setting a long time.
Thanks, I pulled up her petty coat and cleaned out the scales.
1mouse3
il
You're going to loose your smooth ride.
I have worked on consolidation of plastic bins, down to just weight in a metal bin...
Then sprinkled in some usefull stuff, to make it look like serves a purpose
I also picked up my old bag under the oil and a more sturdy plastic bin, pack the same way holding maybe treasures of past projects from more than a decade ago...
Even tho I added weight, this bug.. had to be caged up for removal. This thing was bouncing around, trying to fight stuff...
Also, made more of a patch to the post for the to the back deck, so have a place to now stash stuff in the truck off the floor. Its two layers right now and need to make it four plus, to plug the hole further.
XOLATEM
Why not? Is it bad for the pistons?
In a word, yes. I had the heads off a shortblock and I coated down the cylinders with WD-40 until I could get to taking the rest of it apart...
Dumb me...
Once I got it apart and took the old rings off and cleaned the pistons...
To my amazement, shock, and horror...the ring lands were pitted like the surface of the moon...
I could not believe it and kept telling myself that it would 'clean up'...
But, no...
no matter what I did, wished, and hoped and prayed for...they did not get any better...
Those pistons were my treasured 'street and strip' pistons...forged and high compression...my darling baby-dolls....
A buddy of mine wanted them for sentimental reasons...so...I gave them to him...
That was a hard lesson...
I also had a hard lesson about using adequate fasteners...and...about listening to your gut feelings...instead of someone else's opinion...but that is a story for another day...
Anyway...don't mix WD-40 and aluminum for any extended length of time...
tke395
