Golden Helmet
Monterey County, California
I haven't been using my truck much, it's had a battery drain issue and if I leave it alone for a week it won't start. When I last tried to jump it, it was so dead even my jump box couldn't get it going, so it's been dead for a while. Day before yesterday I pulled the batteries out (they measured 0.2 volts on my meter), took them to oreilly's, the kids there told me their machine wouldn't charge my batteries. So I take them to the mechanic next door, he hooked them up to a machine that didn't talk back, and next day the batteries were charged and load tested fine. YAY!!!
Today, I finally put the batteries in my truck. I'll spoil the end: I still had to jump it, but the old girl fired up eventually! But before we got to the end, I learned a lesson...... :D
So I put the batteries in their trays. I connected the driver side negative cable. Then the passenger side negative cable. Then the passenger side positive cable. Then the driver side positive cablHOLY **** EXPLOSION WHY IS IT A WELDER NOW WHAT THE ****
Ok... maybe that was a weird glitch, big spark instead of little spark? Tap the terminal again and NOPE NOT A GLITCH. I pulled the ultimate amateur move and put the battery in backwards.
Now, why I got no sparks when I connected the driver side negative cable to the positive terminal, I have no clue. I would have appreciated a little warning spark instead of it becoming a ******* welder. But now I know, don't install dirty batteries in the dark LOL
Pic of the explodey terminal, thankfully there was no damage other than my pride and my soiled *******.
Scotty4
Today is 20f out and ol girl had a rough start for the first time this winter. I maybe could have used the glow plugs a few more times but she still started.
Need to reverify block number before block heater usage. Gonna get a stick on pan heater too maybe.
On a positive note, got the last trim piece for the interior to install later today to keep dirt and snow out of the sill.
miles1400
Macungie PA
i found out the the drain screw on my fuel filter/WS was not all the way tight, it was dripping when running. i tighted it up with channel locks and hopefully that solves the air intrustion problem, i will know in the morning
It's looking pretty good. It's also been so long since I've seen a non A/C truck that I had to look at the gauge surround for a bit to figure out why it looks strange. Then the light bulb came on.:Thumbs Up
Ky85
West
Fixed a loose injector after a smokey mountain morning,
Starter hooking up the block heater on a timer and that truck is ready to go by time work starts
Exhumis
Virginia
22 here today also. Actually had to use the cold start procedure. She started though.
