John Haggerty
Birth Certificate
Brothers,
Yesterday, I finally reached into deep my pocket and changed my starter. I went with the NAPA $250 preminium rebuilt Mistu offset gear-reduction. What a difference! I can't wait for a cold morning to notice the real difference!
However while under her, I about reached the point where the oil leaks are bothering me too much. She leaks about 1/2 qt. per 2,500 miles, which I don't consider too bad. You can see in the pictures that the oil cooler leaks both front and rear. You can also see a single example of the oil pan gasket leaking (just one of many blow thrus).
I'll done oil pan gaskets on 300 I-6's before (jacking the engine from underneath), but obviously the IDI a different beast. How tough is it to change the oil pan gasket? What's the easiest approach to take? I figure that somehow while doing the oil pan gasket I'd do the oil cooler too.
Thanks,
John
Thanks,
John
