It's very simple - I've done quite a few of these. You are going to need some basic tools and a dial indicator and a torque wrench ft & in lbs.
You basically change two things in a gear change - you can change the pinion in and out and you can change the carrier to the left or the right. Every time you change the pinion depth you will need to change the carrier to the left or the right.
Pre-load is just how much rolling resistance the pinion has when you spin it - it is adjusted by adding or subtracting shims on the neck of the pinion. This is where the in/lbs torque wrench comes into play - once you setup a few sets of gears you won't need it anymore as the feeling is obvious.
The pinion head has some numbers written on the head that will let you know how to adjust your shims - most gear swaps I've done I've been able to just switch the R&P without changing the shims and the pattern is actually really good.
The rule of thumb is to get your back lash into spec and the run the pattern. The BL is very important, you have to get it between .006 and .010 - not a lot of room to play with. Get yourself another set of carrier bearings and hone them out until the slip on and off the carrier, you will be pulling them on and off quite a bit to get the correct adjustment.
This is what you want to see -
The pattern could have been a little further away from the center, but this will survive chromoly shafts and 44's no problem.
Put your reading cap on - the link that is listed below is BY FAR the most comprehensive guide you will need to performing a gear swap. Billavista is the man- good luck, the article will give you all of the knowledge you need. Be confident going in and you can just use logic to get the pattern where you need.
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
