School me on obs dash
I believe the filter above the alternator.
Man now I want a tuna sandwich...
Greenie
so a bullnose had a real oil pressure gage as I recall is that right?
if so that sender should be a better fit for this mod don't you guys agree?
only issue would be the thread pitch and fitting the 7.3 sender location, any input?
tia
looks like the lpop sender is real close to the same range as the 6.9 -7.3 ...
I bought an oil pressure sensor for a Ford gas V8 engine prior to 1988. Threads match and there's plenty of room. . There's no numbers on the dashboard oil pressure "gauge" but the needle will reflect actual pressure rather than the on/off factory sensor. Something like this....https://www.npdlink.com/product/oil-pressure-sending-unit/106865
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
Cool
Looking at this, it sandwiches tween the turbo and glow plug relay...
I'm going to back burner it and grenage a set of dual transfer cases...
