Couple months ago the battery light on the dash was on momentarily then went off - seemed like a blip because the after market voltage gauge seemed to be above 13.5V.
Now today I’m seeing the dash battery light come on/off again. While parked with the battery light on I can Rev the engine and the voltage gauge does not change. Then the light will turn off and While parked I can rev the engine and the voltage gauge goes up
I measured the volts of the batteries and they are both about 13.1V.
Any idea what the issue might be here? I’m not sure what conditions make the dash battery light turn on.
Am thinking possible connection/wiring issues.
Alternator has the date 2013 on it replaced by a PO.
Truck has aftermarket equus voltage gauge.
Normally when driving the voltage gauge will be around 13.8V
Gonna drive the truck for the day and monitor things
