Replacing Fss solenoid
SuperDave
douglasville
I need to replace the fss in the burned 7.3 I have, the old one still works fine but the plastic insulators are a little melted and I'd like for that to not be a problem later! Problem is I can't remember how to change one as I haven't had to since the 90's but I do remember if you get it wrong the engine will start and go W.F.O with no way to shut it down so I'm seeking advice on how to replace it correctly instead of converting an engine (that has already survived a fire) into scrap metal. Thanks and happy new year!
I think that if you have another IP with one that works, you could just swap the IP tops. Unless someone corrects me that is.
lewisstevey7
