Reman injection pump
ah1988ford
florida
Hey got this pump off the motor IAM rebuilding does anyone know how old it is from when it was remanufactured? Or who remaned it? Just want to know if it's a piece of junk
Clb
Another old truck
nannyfornia
Try calling standyne and give em the nomenclature info?
Waste of time
It was rebuilt by a stanadyne shop or possibly the nearest reman depot. You can be assured at the time of build it was top quality.
ah1988ford
florida
Waste of time
Would you run that pump? Also I heard you rebuild these pumps to
If you have a clue as to the miles on it, that will tell you your answer. No matter who remans these, they will all wear out in about the same amount of miles.
I would clean it up externally and run it as is.
It's 675 for me to do a stock or better than stock pump rebuild right now.
Also the c91 is an international suffix if you look at International part numbers they all have C something on the end of them so it means nothing as far as date
