No, it wasn't gross weight. We talked about that and the guy I talked to was very familiar with the 6.9 and 7.3, said he had one as a matter of fact. My F250 weighed 6300 pounds empty and I would guess that 4000 of that was on the front end!
With my old set of tires and the 4.10's, I could spin the back tires at will at about any speed! I asked him about load and he said if you haul 5 ton and break them, I will replace them.
I haven't seen anything built quite like these, but haven't seen many anyway. I can tell you that he also made a set for the local volunteer fire department, and their gross was 13,780 lbs as they had a water tank on the truck they put them on which was the reason they wanted them. They have had them for 2 years and prolly 50 or so fire runs, not to mention the truck sits loaded all the time with water in a garage as it used for rural firefighting in areas where things are not real accessible. It is an old international truck, but I can't remember all the details of what it was, it was an older unit donated by one of the other departments. I have hauled 3 ton on mine, load only and my truck now weighs about 6700 empty. I am running 10 ply tires that rated at 3800 pounds each IIRC.
At any rate, I have hauled 3 ton or close to, weighed at the stone quarry with no problems. I don't even have the overload spring brackets on it yet because I can't find the ones like what came off of it, all metal no nylon insert.
The guy may be full of crap, but if they will work with a 3 ton load, I am happy. I don't haul more than that at once anyway other than on the trailer, so I am good to go and that kind of load is pretty rare and pretty short. The stone quarry is about 10 miles from me, all good blacktop road. Will be doing quite a bit in the spring when we go full swing on the house!
Still looking for a backhoe and operator Aric, care to venture south?
