Just another comment that I don't think has been made yet. While it is true that I do not have any data to support this claim, it is my belief based on touching and feeling the temperature of things under the hood immediately after a highway run, that the fender areas not directly behind the radiator, run a good bit cooler than anything in line with the rad. It makes sense that for the most part, air flowing through the radiator and fan, is then made turbulent by the engine, before it can pass out of the engine compartment by deflecting below the firewall. In essance all the heat and air that was or is in the engine compartment, is vented out of the bottom of the truck. If you compare and use your imagination in observing the possible airflow over and around a stock engine, with a stock air cleaner, we see that....
There are a ton of things to get in the way. What strikes me most prevelant however, is the air cleaner itself, which sits high, and is in the direct line of fire from air exiting near the 12 O'clock noon postion of the fan shroud. This is the air which seems to have the best chance of passing over the motor, back to the firewall, and down. Most of the air from the shoud has already collided with the motor and accesories, and is displaced down below the heads, flowing over and under the manifolds in the direction of the drivetrain tunnel where the largest low presure area must surely be developing at speed. The air cleaner, and factory air snorkle almost form an air dam across the drivers side of the engine compartment. At least on this model however, the air intake is situated to intake only air from outside the engine bay. Unfortuately, the air cleaner and it's large external surface area are constantly bathed in the hotest air coming from the radiator, that which is being returned from the engine into the top tank. So, it makes sense to think that if one were to view a thermal image of a radiator, it would be brightest or hotest at the top, and cooler as it gets to the bottom. This would indicate that the top of the engine is the area which will recieve the hotest air, and since it is farthest from the bottom of the truck, also has the longest to go, and hence the ability to heat more parts effectively. Compare the above photo to this one....
Never mind the fact that it has electric fans, although as an aside, its clear that more hot air will be directed towards and below the heads with this setup. With only the intake hat, and a hypermax turbo in the back to block the top level air flow, the air intake is not daming up the warm air, and consequently is not being heat soaked. So perhaps the kind of air cleaner, and piping you have and where you locate it, is just as important as where the air comes from.
