fields_mj
I've been driving my truck for about a month now, but the privious owners didn't drive it much, and never let the tanks get below half full. After reading several posts on here and on some bio-diesel forums, I'm thinking that it would be a good idea to do some kind of shock treatment with a biocide. Lots of folks on here have recomended the white bottle Power Service as a winter additive. How does their Bio Kleen do?
Thanks,
Mark
Thanks,
Mark
I hadn't heard anyone mention that yet, but you just described exactly what's happening.
Just teasing you Heath.... Yes, the fuel pickups do seem to fall to pieces but. The fix for the front tank is easy. No need to drop it cause you can reach the opening with ease. Just get under the truck at the front tank and look for the fuel line and return connections. Remove them, knock the retainer ring loose and lift out the sender assembly. Add some hose and its done. Watch the tank to cover fit. There is a locating pin that lines things up so it goes back together properly. The rear tanks is much harder to get to... Sorry..
