swampdigger
Keep in mind.... the diesel automatics have the bottom of the bellhousing machined away so you can get to the converter bolts, since they are blocked from the front by the very large oil pan.
Sounds like a guy could cut off the bottom of the bellhousing himself, and make his own inspection plate. I wonder if the diesel torque converter does indeed fit inside the BB bellhousing?
That'd be alright... drill some new holes, make an inspection plate, and you could do an automatic swap from a BB C6 that came behind many 351M/400 and 460 vehicles.
