dyoung14
Is getting worn out
Or like that guy who made that 6.2 powered tractor run 2 db2 pumps
ya david same idea run 2 pumps that flow over 1/2 a db2 you could run 2 db2 pumps but the injectors may not flow enough fuel
88 Ford,
CTR2(SW) Sutton here
With the right pump, my turbo is sized for 40-50 psi at 4500 RPM. No way that will happen on a stock pump, but still should be in the 25-35 psi range.
If the Super Moose will move the fuel I need, that might be worth a look. Trying for about 4x what a stock pump moves... That why I was wanting to go from 2 plungers to four.
About $250 or so in materials... Plus a LOT of time cutting, fitting, and welding. Plus another 200 or so for ceramic coating.
Or were you talking about having me make you a set? Might could make that happen...
I won't be getting them back for a couple weeks, but when I do I'll let everyone know how it goes.
Lesson learned for today... 5" exhaust parts ain't cheap. Just ordered some mandrel bends, tubing, stainless flex pipe, clamps, and to top it off... A Silverline polished stainless angle cut stack.
For the fuel lift pump, I'm going with a Holley HP-150 pulling through 1/2" line with a FASS suction tube installed in the rear tank. Going to delete the front tank from the fuel system altogether and use it for gasoline to feed the Onan genset. Eventually I'll install one of those 38 gallon replacement tanks in the rear. Driving on 19 gallons is for the birds...
This will keep me busy whilst I wait for the ceramic coating of the manifolds and turbo pipes to be complete.
