WrickM
3" should be more than big enough for anything you need. Engine size does not really matter, what really matters is the power (hp output) of the engine. Whatever the engine size hp is created by fuel in air igniting. True diesels do that more efficiently but really there isn't a huge difference between 300hp from a 2.5 liter engine with 25lbs of boost and a 7 liter engine making 300 hp when it comes to amount of exhaust created. (there are some differences ok, but when it comes to final exhaust size their aren't) 3" can support over 400 whp turboed and well over 300hp NA.
i know it's counter intuitive for a lot of people but engine does work (measured in hp) and that work is the simple output of fuel and air burning. A certain amount of fuel and air created x amount of power. there are variables and that does change the volume of exhaust but only slightly. really the only difference that matters is the efficiency of the engine. the higher the efficiency the small the amount of air/fuel needed to create x hp and hence a proportionally smaller amount of exhaust. so our somewhat efficient diesel actually produce a little less exhaust per hp than most gassers.
