Open plugs/connectors
JackJ217
Cleveland Ohio
I’m wondering if anybody knows what these open/capped plugs are for? This is the drivers side right under the brake booster and cruise control vac canister.
87 f250 6.9 4x4 originally an auto c6, in the process of swapping in a zf5.
First plug has a cap on it. Wire colors are Red, yellow, black, brown
Second plug also has a cap. One red wire, one green wire.
Third plug is open with just a green wire going to it.
Fourth plug is open with a red/lt blue wire and a green wire.
There was also 3 cut wires tied together with electrical tape coming out of the main harness that goes through the firewall. Red/yellow, red/white, and black/blue or green - can’t tell which one
Is one of these for the manual trans harness that I can tie into for the neutral safety switch and the reverse switch?
You should have a plug in the same area that feeds a harness that goes down the frame to the c6 and the transfer case. This is the harness that has the neutral safety. I had a donor truck when I did my zf swap, all I had to do was to unplug this tranny/transfer case harness, and plug in the tranny/transfer case harness from the donor, no wiring to do at all.
If you do not have the zf harness, you need to get into this wiring harness to the c6 and find the red/blue wires, there should be two. Cut these two wires on the tranny side and twist them together, this will complete the starter circuit and let it crank over, since you will no longer have a neutral safety switch with the zf.
JackJ217
Cleveland Ohio
Thanks. That’s the main thing I’ve been trying to figure out. I did have a donor truck but somebody had robbed the harness out of it before I got it :idiot:
On the other open plugs, they had a trailer lamps relay option that you probably do not have, and they also had a marker light relay option that the dually pickups came with. The brown wire is the marker light circuit.
This diagram shows the cut wires on the left side. They were for a trailer brake control.
XOLATEM
Virginia... in the brambles
Having a wiring diagram is one of the most helpful things that a man can ask for. Puts you right on track for answers.
I always appreciate @franklin2 's input. One of the sharpest, no nonsense mechanics I have ever come across. 'Nuff said.
I learn something every time I read what he has to say.
There, I said it.
.02
Postscript...
After thinking about it for a few minutes I want to thank all of you guys and gal for teaching me pretty much all I know about the diesel engine in my truck and how to keep it running by deciphering the mystery of its principles of operation.
Thank you all...!!!
.02
JackJ217
Cleveland Ohio
There, I said it.
.02
Postscript...
Thank you all...!!!
.02
Is there a place online with the full wiring diagram? I would love to have one but I don’t want to spend near $100 for one on ebay lol
XOLATEM
I hear ya, but sometimes spending money can't be helped if you gotta get something running or otherwise figured out in a hurry.
So far, I have been able to find what I needed here...but I have thought about going on Rockauto and getting the tech discs they sell.
Look into that and see if it suits ya...
Good luck and happy trucking,
.02
onetonjohn
California
This is pretty awesome. And Free. It's for Bullnose, but may not have changed a ton.
If I could find a good paper copy, I might buy on in case the internet goes away. Copyright must be up on this. I think they are 25 years. One of the benefits to having an old truck I suppose.
Kdo58
Puyallup washington
JackJ217
Cleveland Ohio
JackJ217
Cleveland Ohio
@franklin2 in the harness that goes to the trans, I’m seeing that the black/pink and pink/orange are both for the reverse lights. Is one power and one ground? I was able to get the pigtail for the reverse switch for the zf5 from the guy I bought the shifter arm from, so not sure what year the truck was. It has a black/white (or pink?) wire, and the second wire I have no clue. It goes from blue/white to purple/orange and then back to blue/white lol
