A little update
Lots of good info here, Thanks so much guys.
I finally took both heads to the local IH shop that just does diesels. They're shop rate is over $80/hr, but I decided to just bite the bullet and pay what it takes to get this thing fixed.
The head mechanic had already heard about these heads, so he took it on. While I was there, he Mic'd the thickness of the heads, checked the flatness, and warp, and had a look at the pre-cups.
He said it all looked really good. The heads are flat(less than .002 overall), and not warped, and he said the precups look better than he would have bothered with, and they are all nicely seated and very nicely polished and flat, so that's a vote of confidence.
Said that if he had heads that had more than the .0025 protrusion height presented to him, he would not put them on a block and sign his name to it. He added that if one of his junior guys had machined them such that there were some that were .003, and others as high as .007, he would never have allowed that head to be sold to a customer till it was shaved down to within specs, and that it would definately account for leaks if there were that much difference between them. He said that mine were in pristine condition, and that I should just slap 'em on and get on with getting it back together.
I never did have anything done to the block(other than bore and balance) so I've never suspected the block at all. The studs are also not really suspect, especially now since I found all the ridiculous precup heights. The studs actually have a fine thread at the top.
So, I guess that start up will be the final analysis, but for now it looks like the precups were definately the problem.
Again, I want to thank everyone for all the support and problem solving, and lets just cross our fingers and hope it runs like a charm.
I'll put it back together probably this coming weekend, and I'll update on how it goes...
Zigg
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
