Well, I had the one head checked for flatness and warpage(and pressure tested) by a local IH machine shop. They said it is dead flat, and pressure tested to 40psi for 2 hours and never leaked a bit.
So, I used an aluminum level on the head, and it seems pretty flat: I wasn't able to slide a .002 feeler under it on the surface. The pre-cups are allowed .0025 protrusion, and there is at least that, maybe closer to .003. Curiously though, the only place where the head gasket appeared to have sealed well is right around the pre-cups and on the whole intake side(where the pre-cups sit)
I checked the block for flatness, and couldn't find any are with more than .003 clearance overall, never mind over 6"., so that checks out.
I put the head on the block with the dowels in place, and tapped it down, and the most I can fit a feeler gauge in there anywhere is .003. Couldn't get a .004 one in anywhere.
I did measure the thickness of the gasket that came out. This might be something. Most of it is .065 thick. there are some edges(along the intake manifold rail where it doesn't get crushed) that measured closer to .075. But really interesting is on the exhaust side, where the gasket doesn't get crushed, it is essentially the same thickness as the part that got crushed. Like it either had been previously flattened, or just had no room to crush at all?!! The flattened part is just the same thickness as a part that never got crushed?!! That doesn't seem right.
I measured the new IH gaskets that I've just got, and they mic out to over
.085 evenly overall.
At this point, I'm just at a loss what to do. I really believe in the Studs and don't want to go back to the bolts. I've checked everything over and over, and I'm not running out of threads or anything like that. I'm starting to think I'm going to just put on the new gaskets and take a chance. Nothing else seems to come up that can explain this.
Zigg
