What kind of leaks? Fuel, oil, tranny, or coolant or all of the above? Did you replace the return lines with the injectors? Oil leaks could be water pump, front main seal, valve covers, anything in the turbo plumbing, rear main seal. It sucks to get taken for a ride, I know you spent good money on this truck, if it was sold as a project and tired old warhorse for 1000 bucks I bet you'd not be complaining. I would say you need to check the compression to see if its within limits and if that checks out be on a mission to fix your leaks and get the timing set(with tools) to 8.5*BTDC with the pulse method or 1-2ATDC with the luminosity method.
