zmck150
Hey guys i havent been on here in a while but you all are very helpful everytime i ask a question. Some backround information is 93 f350 7.3 idi n/a cc lb drw 4x4... it has a jasper reman (unfortunately) tag says 185hp model. I bought it a while ago and was a idiot.. didnt realize there was oil in the coolant. Posted here and researched problems that would cause this (oil cooler orings and gaskets / having a bad cooler) so i replaced the o rings and gaskets. Thought problem solved.. nope still loosing oil into the coolant. Then searched again and found out i might have nicked the o ring causing a leak again.. s i replaced it a second time, still loosing oil. So i hapoened to pickup anoher complete 7.3 idi 185 hp n/a for cheap and took it apart to rebuild and drop in as a replacement. Long story short funds are tight and thats put on hold. So i looked at that oil cooler. ABSOULTELY NO TRACE OF OIL AND ANTI FREEZE MIXING.. So i assumed that that oil cooler off the spare had to be good. Replaced o rings just cause mileage and age are unknown. Put that "new" oil cooler in my truck. And again, its still mixing. Im getting really really sickof this and dont know what else to do next. Is it possible its a headgasket? It starts and runs good.. it doesnt really smoke (any more than any other straight piped stock idi) or maybe i have a crack in my block.. imnot sure im guessing at this point.
Any input is greatly appreciated thanks in advance
