Clear Me UP!! please....
OK, just so I'm clear too. I'm gonna go slow & use lots of words....
Zigg, TC, the holed we're talking about punching is thru the old CDR hole, Same hole that the turbo drain tube fits into/thru the rubber grommet if we're turboed. Right?
I need to go see if I can find my old valley pan tomorrow. The baffels, 3 layers of them (or 2 layers under valley pan), are under here. Holes enlarged or poked thru baffles to enlarge or whatever...make'ur drain!!!
Now other question....the threaded drain plug with the square drive, at back of valley pan, is the plug open or does it need to be out to drain externally? Or am I thinking about some other external drain that drains oil, antifreeze, crud, etc that collects on top of valley pan?
Zigg, in your first pic, if I remember mine correct, the drain hole drains externally thru the threaded hole in your pic. The adaptor plate, between tranny & block, bolts on rear of block. With the adaptor plate in place, the external drain has to drain sorta
infront of the adaptor plate, right? If there is build-up of crud in the valley pan drain hole
OR in front of the adaptor plate, then the valley pan has trouble draining off, out, & away....
My experience & near misshap 2-3 year ago.....Down at local carwash & washed the heck outa my engine. Drove about 3 miles. For some reason later I decided to ck the oil. I had way toooo much oil on dipstick. Changed oil there before going anyfarther.....drained about 1 1/2 gal of really clear, sparkly, clean, fresh water from crankcase, along with some oil!
As it turned out....the grommet around turbo drain was virtually near gone, And the drain in back of valley was crudded & plugged...thus letting water drain into crankcase thru turbo drain tube hole/CDR hole.
I was very lucky!!! & it did throw a chill thru my heart, down my spine...all the way to my toes!!!
I very carefully wash the engine now....check oil dipstick before driving off....
I'm gittin too old for these kind of scares....it gave me carwash psychosis
