Oil and Filter
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Sorry this post is so long, this is verbatim from www.ihcubcadet.com...... (The order of the attached thumbnails are in the order of the following text...... more photos in the next post)
Here are the photos of the hydro filters that were cut apart.
all_filters
Above are some of the various filters that cross to the Cub Cadet OEM PN: 923-3014
Fleetguard PN: HF6096
Wix PN: 51084
Stens PN: 120-265
Parts Master PN: 61085 1-16A
Fram PN: PH16
cc_filter_1 & cc_filter_2
Above is the Cub Cadet Filter.
fleetgard_1 & fleetgard_2
Above is the Fleetguard PN: HF6096 filter. This is almost exactly the same inside as the Cub Cadet filter.
wix_1 & wix_2
Above is the Wix PN: 51084 filter. This is similar to the Cub Cadet filter except that it has a separate steel nipple instead of being formed as part of the fiter end.
stens_1 & stens_2
Above is the Stens PN: 120-265 filter. The main difference between this and the Cub Cadet filter is the spring which is a piece of spring steel rather then a coil spring.
parts_master_1 & parts_master_2
Above is the Parts Master PN: 61085 1-16A filter. The filter element is nearly the same as the Cub Cadet filter it uses the different spring and has a rubber seal instead of the steel nipple.
fram_1
Above is the Fram PN: PH16 filter. This has cardboard ends to the filter instead of steel and there is less filter area. It has a rubber nipple or seal and an odd spring with a plastic retainer on a small coil spring inside the spring steel. I don't think I'd use this one. It does have a really nice rubber grip on the filter housing though.
This really helped to convince me not to use fram filters.....
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
The last 2 pics.....
Full Monte
Campbell, CA
Wix oil filter and Delo 15W40. I am amazed at how clean the Wix filters keep the oil. When I have engine leaks that I haven't fixed, I run straight Supertech 30 weight
BigRigTech
Diesel junky
Nova Scotia, Canada
Fleetguard filter and rotella T. I stick with what works - good filters and good oil every 3 months regardless of the mileage....Usually 4000km or less between services.
dave186
Idaho
wal mart is the best price i have found for any oil filter for these trucks. FL1995 is $9.95 here. I agree with the fram crap, I have seen more than one cause problems. You couldnt pay me enough to put one on my vehicles.
gatorman21218
Ashland VA
what about fuel filters? I just picked one up from NAPA today and it was 44 dollars:puke::puke: Where do yall get yours? I would love to run a motorcraft one but dont know where to get it
dave186
Idaho
I have been picking up cases of fuel filters on ebay for dirt cheap. the last case was IH branded Racor filters.
CDX825
filtration nut
Litchfield,Ohio
Check out fleetfilter.com if your looking for wix filters. They tend to be cheaper than Napa.
jim_22
Cape Cod, MA
Wow, $44 is price gauging. You can get Wix 33426 (with water drain) from Filter 1 for aound $25 or so, don't remember exact price, and with free shipping.
dyoung14
Is getting worn out
spencer,tn
do they have a filter with a water separator built into it that i could run on my 6.9
gatorman21218
Ashland VA
who are you talking to dyoung? The FD-3375 is all they list on dieselfitersonline which has the removable bowl underneath for a 7.3
Vinceslamer
