O/T Spare Tire Hardware 1991 F350 DRW
bulletpruf
San Antonio, TX
Can anyone tell me what I'm missing as far as spare tire hardware for my 1991 F350 dually? I think I need a bracket to hold the top along with a wing nut, but should something be holding the bottom of the wheel, too?
Thanks
bulletpruf
San Antonio, TX
You're missing the tire :joker:
On mine I put the hub side facing up, then just lifted er up and sent it. I did use the wing nut on the back side.
Ok, I found the below image; now I'm more confused. Does the retainer - part 4 - fit on a dually? Or am I supposed to flip the wheel over and use a wing nut on the back of the flat bar that's pictured and does't have a part number?
That retainer is for a SRW wheel. I'll see if I can take a photo of mine this evening on how I made it "work"
I can see marks where the tire went against the fuel tank so the hub must have faced down and sat on the cross piece.
Mike_Dawson
