silexis
Does anyone know a part number or size of the oil ring between the turbo and the snail?
The turbo is an ATS Aurora 2000, which might be the same housing as the 093.
I had oil residue around the turbo and snail, wrapped some silicone tape around all the connections to seal them up, and found that on higher boost, the tape acts like a reed and whines as the air leaks past it.
Makes it easy to hear what boost level I have, but I'd rather that air be going into the engine.
The silicone tape fixed the oil leak.
As a side note, if I ever get any diesel leakage around the engine, it is almost always a loose supply line to the injection pump that needs a little snugging up.
