Now Intercooled
Double-S-Diesel
parts seller
derry pa
Next step is done , new used 94-97 turbo and a 02 intercooler , 99 y pipe
all hooked up. still need to test but there is too much crap on the road way.
next step is the 99.5 + turbo.
tjl
Diesel Nut
Nashport, Oh
The kit I used routed the ic tubes a little different. I didn't have to cut anything. I just had to enlarge the opening on either side of the radiator.
Double-S-Diesel
parts seller
derry pa
I want to convert to the 99.5 and up pedistal and run a Garret BB turbo.
it is possible, that is my next step. I put the 3" body lift on for more firewall clearance.
Russ
In my set up cutting the inner fenders was needed. there was no way around it I plan on putting a rubber piece over the openings. them molding some fiberglass in.
dont for get the 3" body lift makes my setup special.
but as for the tubes the stock SD tubes fit perfect, the only mods to them was adding 2.5" to the IC end of them.
Now without the lift, stock SD tubes will not work as well.
Tims set up and most other setups do not require to cut the inner fenders, the tubes on them are 2 or 3 piece for them to work., but those tubes would not have worked with the lift..
Double-S-Diesel
parts seller
derry pa
Travis you know me, funcion before prettyness
hell I havent even got to run it yet.
hopefully my wheel well liners are in
Staff online
