nos?
dyoung14
Is getting worn out
spencer,tn
i believe the thing your talking about with copper is just a distrabuter to spread the propane more evenly in the air stream
Propane acts as a catalist to burn more of the diesel. NOS will not burn. What it does do is add more oxygen to the burn.
Willie Two
Retired Firefighter
British Columbia Canada
idi 97 ;
I did mine all homemade, had help / advice from a local fellow who does propane conversions for taxi cabs. I have three safety features: two stages of regulators, engine oil pressure required to let the system operate, and a flashback arrestor on the supply line. Generally speaking it is turned on at almost wide open throttle by a micro switch but I also have two manual switches on the dash. One turns on the system as a master control and the other overides the throttle control. I also have two LED lites to monitor the system while I drive, one is to show the system is on and the other lites up when the propane is flowing. I do get better pulling power in the hills and better MPG's. I think the diesel fuel burns more complete. Biggest problem is there is a big variation in the fuel / propane mixture as you press on the go pedal when in manual mode something that I think the "kits" account for with some electronics.
97idi
mt airy/maryland
idi 97 ;
so is it better to run the propane into the intake before or after the turbo? also would mulitple injection positions be better than just one? thanks
97idi
mt airy/maryland
Sorry I don't have a turbo and I have not tried multiple positions. ( OK ! OK! I'll add in the " since I have been married " part ) :rotflmao :rotflmao :rotflmao
HAHAHA SORRY.... BUT WHAT KIND OF FLASH BACK ARESTOR DO U USE? ALL THE ONES THAT IVE SEEN DONT WORK WITH PROPANE
Willie Two
Retired Firefighter
I bought it from a welding supply house, intended application was a welding torch set. I also bought my primary and secondary regulators and a 20 foot hose to run under the truck using factory made connections. All connections from tank to the engine are reverse threaded and the line clearly labeled as a flammable gas line. I did this just in case some mechanic may be working on my engine / truck in the future. My operating valve is electric and I bought a pressure switch that closes @ 35 PSI. (tied into my oil pressure line.) This is wired in so nothing works unless the engine is running. They also make something called a " Tippy " safety switch but I did not put that into the system thinking I could be climbing a steep hill :dunno The switches were purchased from a forklift repair shop and are propane approved. My throttle mounted micro switch was also purchased from the forklift shop and modified to suit. Have fun, think safety first and use a bottle of compressed air to test the system before your hook up the propane for the first time. PS : I leak test the system before every mountain trip, never leave the tanks on overnite and someday I plan on adding a propane gas leak detector under the hood and wiring the indicator back into the cab. They make them now for RV trailers where the remote sensor is in the up front propane bay and the alarm is inside the living quarters, 12 volt operated I believe.
sootman73
Wauseon, OH
i would think it would be better to put it before the turbo that way it will always flow the same.
if you put it after the turbo you will need higher pressure in the injector to keep the flow the same or increasing as boost rises. like when filling a tire. an empty tire will blow up fast but as the pressure in the tire increases the slower the air flows into it. see what i mean? or maybe it doesn't matter:dunno
97idi
mt airy/maryland
yeah that makes alot of sense actualy i didnt think of it that way, cuz if the propane was always runing at say 5psi and my turbo goes above that it would be pushing air back into the line
FordGuy100
Silverton, OR
I dont know about you guys, but it just doesnt seem right to push propane through the turbo. Probably nothing wrong with it, but I just dont like the sound of it LOL
97idi
mt airy/maryland
well does anyone have install instructions for a propane kit thats out on the market for any truck or seen a kit?
Bo17
