seawalkersee
It needs a turbo...
Loctite or any other brand of thread lock doesn't do anything for torque... it's function is to stop the nut or bolt from backing off the torque given. Dirty nuts and bolts will not give a true torque reading. Clean and dry , or clean and lightly lubed gives you a better shot at making your number. If you want to be exact, anything on the bolt/nut changes the actual tension vs torque indication.
I agreed with you 'till this point. I have personally had loctite on a thread and broke the bolt with less than 30 lbft. It had no sign of tightning down either....
Next, I wonder if there was a difference in the pitch of the flywheel and the rear flange of the crank. Not sure how much it has to be off, but f it wobbles, even enough (for example) .00059 when tollerance is .00055, can that cause the failure?
Saleen has been building 400 lbft/HP engines for years. They said on some of their higher HP engines that they could use as few as 3 bolts for the flywheel with no problems.
SWS
