On the subject of torque and thread failure. I spent much of my life working on jet engines where a failure of critical bolts in the rotating group would cause millions of dollars of damage and death, so a lot of attention was paid to being exactly accurate.
RPM typically ran in the 40,000 to 90,000RPM range and EGT of the rotating group could be in the 3600 degree range.
All that said, for the main rotating spool we typically used one very expensive bolt shaft that was tightened hand tight only, after being tensioned with a hydraulic fixture and a dial gage that measured the length of the shaft before and after tension. The fixture tensioned the bolt shaft at 20,000 lbs. [different for various engines of course] and there was a strict limit on how many times that bolt could be tensioned in it's entire life time. Threads were ALWAYS Xrayed before reuse to detect cracks and in almost every case where a crack was found on these VERY expensive bolts,,, it was in the thread form due to the stress risers imparted into the metal in forming the threads.
If you want to be exact on how much stress you are putting on a bolt with a torque wrench,, measure length before and after tension.
Loctite or any other brand of thread lock doesn't do anything for torque... it's function is to stop the nut or bolt from backing off the torque given. Dirty nuts and bolts will not give a true torque reading. Clean and dry , or clean and lightly lubed gives you a better shot at making your number. If you want to be exact, anything on the bolt/nut changes the actual tension vs torque indication.
The good news is, this ain't brain surgery and nobody dies from falling out of the sky. The bad news is,,, it comes out of our pocket when it breaks.
It's my opinion that the "Lucky Mod" puts bolts in a position where they are placed at or near their failure limits not from torque on the nut, but load from the flywheel forces that are added to the torque load with every piston stroke "shock". That's why the DMF springs fail after use,,, and defeating the DMF with solid bolts gives the hammer of the diesel power shock no where to run.
