next project
next project
  • ats turbo
    Votes: 6 54.5%
  • zf5
    Votes: 3 27.3%
  • stacks
    Votes: 1 9.1%
  • shackle flip and RSK
    Votes: 1 9.1%
  • Total voters
    11
black diamond, wa
i have some spare time and some sunshine finally.. time for the next project. what should i do?
1)ats turbo 093 (everything but the dipstick tube)
2)zf5 (everything thats needed but maybe new clutch if i want)
3)smoke stacks (need to purchase)
4)shackle reversal and flip kit (need to purchase)
what should i do? i was thinking zf5 because i dont have the tranny tube for turbo kit. what do you guys think?
Black dawg
sw mt
I wonder if you can get the factory turbo dipstick and tube from ford still?
gonecrazyi
florida
I think I have a spare somewhere.
The turbo will make a Hugh difference. With my emls my truck was a dog, especially with a trailer. Post turbo I have no problem pulling away from traffic and can cruise at 70 with a loaded trailer.
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
If he wants to use the dipstick and tube from a '94 IDIT then i wish him good luck. i say this because ford or their supplier no longer makes the tranny dipstick for the '94 IDIT. For the tube i don't know.
black diamond, wa
Would you be willing to sell that spare?? Also speakin of turbo do you think the ats valve cover set up is better or the banks ip cover set up?
I feel partical to the Banks CDR system. I like how it pulls the oil mist up thru the gears. I'm not sure if the gears get any supplied oil feed. Might just be from splash...:dunno
FORDF250HDXLT
Maine & Oklahoma
none of the above.
you lost focus on what is most important imho.
you have an actual gear ratio of 3.38:1 with 4.10 gears and 38.5" tall tires.
your truck needs some gears to help bring ya back to a performance gear.
a nice set of 4.56 gears would bring ya right up in the happy medium of 3.75 gearing,that would really make ya smile.
drop in a set of 4.88's to get ya up the performance field a bit more with close to 4.10's (just shy at 4.02)
personally id go with a set of 5.13's for a truck built up like yours for an actual gear ratio of 4.22 since those tires are big and heavy,it'll feel closer to a truck with 4.10's and stock tires.
it'll go so much better you'd think you dropped in two idi's.;)
anyway,that's my 2 cents.
p.s.
after that,id be working on the front springs.
so then id pick:
simply because a truck riding on 8 front leafs isn't anyone's idea of an enjoyable ride lol.
black diamond, wa
That is very true.. I guess I was leaning more towards the turbo or 5 speed just because I have them already so wouldn't have to spend more right now. But I see what your saying. Im thinking I may have to go the 5.13 route. Is the older 10.25 (pre 92) built any different then the post 92? I have a 91 and a 97 axle. What would be best to use? The 97 is limited slip
gonecrazyi
florida
Besides being a bit slower to take off, my truck still pulls pretty hard at 12psi.
I do need to put my smaller tires back on to see what I could sd with all my gearing back. I'm also running my tires at 35psi instead of 70 due to a very rough ride.
