New plugs wont start now.
Cainon
Smithfield
If it starts by plugging it in first. Will it damage it if I drive it?
Nope. It's just like driving it after the glow plugs have warmed up the precups enough so they don't have to be on any more.
Fred Hemer
Nanaimo B.C. Canada
Haven't been around here much latley However I couldn't help but read that you developed a knock? that knock is likely a glow plug tip on top of a piston the consensus is right ditch the oem controller My 86 did the exact same as yours The only diffrence is I had already installed a button between the controller and the relay ! The controllers tend to fail to the on position !
ulmapache
Reedsport Oregon
Ok...planning to replace glow plugs AND GPC...but I see two different types on Rock Auto... Shows one like in the photo in BBJordans post (super motors) and another one that appears to look like a solenoid... Is this something else that should be swapped out? What gives? Thx!!
ulmapache
Reedsport Oregon
Am I correct in assuming that if I have a button on dash to activate glow plugs, then the GPC has been bypassed at some point in time? Thx! Still learning these things...
Jason1377
Arkansas
Correct if you run a push button for glow plugs the controller is not used also @Thewespaul has all the items needed but the push button that can be bought anywhere
ulmapache
Reedsport Oregon
Question: When installing new glows, should I use any thread lube, or never seize, or maybe thread locker...blue, or less? Or install them dry... Thx...
Jason1377
Arkansas
There should be a tech article on glow plug replacement my own personal glow plug change I never used and lubrication though I sure you can
Selahdoor
Index Wa
Anti-seize is the only thing I have used.
And that, only because of the trouble sometimes, getting them to come out.
Although silicone dielectric grease might work instead.
chillman88
Central NY
Might be up to personal preference but I use never seize on everything, glow plugs are no exception. Had to pull out a bad Motorcraft plug last week, came right out with ease!
