rhkcommander
Got a 6.9L 4-speed banks sidewinder turbo - doesn't want to start cold and hot. compression start only. Just replaced a bunch of dead Champion glow plugs and gp relay. Feel free to quote a part of this message if you only want to answer a piece of it.
Found air intrusion where fuel line meets injectors, diesel was pouring out - guessing oring replacement will help?
Another question - how many miles can injectors last before replacement? I read 100k and these are stock and engine has 135k on it. We were getting a weak cylinder. Added some diesel kleen or whatever and seems like it might've been a stuck injector. Little blue smoke coming out but like I said alot of oil passing the CDR. She's running happier now after a push for compression starting.
what PSI should i get round-about on compression test. If I remember right ford said 185-385, with lowest psi within 25% of the highest
CDR valve is puking oil too as far as I can tell. I'll try and clean the tuna can and see if the rubbers still good. Whats a good thing for cleaning it? Looking for another air filter too, part number 41505 - the guy who owned it before had a K&N on there and torpedoed the turbo... And the alternator... And who knows what else... So its got another turbo. If anyone is willing to sell me a boost gauge P.M. me please. Same with Alt. and other parts. Already got pyro. I'll keep hunting the marketplace too.
I'm new to the 6.9 diesel, just been doing homework and trying to unfudge my truck. Theres a bit of fudge too so thank you for any help!
Also, the original head bolts are on there - would the boost be enough from the banks turbo (if its even banks anymore it has been replaced afaik) - would it be enough to blow a head gasket with stock head bolts and if so anyone know a inexpensive stud kit? I'm kinda poor after buying the darned truck and other things. But I want to do the right thing for the truck. I know ARP's are good studs, and I found another set which were rated highly too but forgot who made 'em. But looks like 200+$ for the studs and then another 130 for gasket kit..
