new clutch install
wannagetrdone
thackerville/ok/usa
Ok bought new clutch from oriellys. it was their hd kit and it came with three pilot bearings. my question is one is brass and is too small for the hole in the crank,the other two are needle bearings that are 1"o.d and my pilot hole in the crank is .962 i.d. thats nearly 40 thousandths of clearance. do they press in the only difference between the two needle bearings are one is a little longer. which one do I use and ideas thanks
south bend clutch
The pilot bearing does not go into the crank it presses into the flywheel if you are talking about a 5.9 cummins
Peter
