N/A Water **** Injection?
payableondeath6
Impressively Ugly
Marion, OH
Allow me to hijack for a moment...
I've got two turbo trucks, and one N/A.
Do you inject the water/methanol before or after the turbo?
I'm just curious as to how to overcome the boost pressure and inject the water/**** post turbo.
On the ford, that won't be such a big deal, as I doubt it's putting out 10PSI, but the dodge is putting out 30 psi.
Definitely after the turbo, for the reason icanfixall said. You'd have to pressurize the tank, there's plenty of info out there for water/methanol injection for turbo trucks...heck I just searched "homemade water injection" on google and come up with a couple good sites, or the splash site is good too ;Sweet
Tractor pullers put it pre-turbo, and feed it right onto the turbo shaft. Of course, they are running 200 pounds or more of boost, and don't plan on using that turbo very many times anyway. Most guys put the mist injector right on the turbo intake hat (which is naturally post turbo). I guess if your Dodge pushes 30, you just need to find a higher presure pump. I think a Ford Bronco factory fuel pump pushes like 60, but I don't know how much it would like water.
Cv axle
