My '89 is dead, what's happened?
nelstomlinson
Delta Junction AK
Parked it a couple days ago, all was well. Today I turn the key and nothing happens at all. Batteries are still fully charged. I can see that the rod along the top of the steering column is moving as I turn the key. I'm starting to think that the big switch on top of the steering column down under the dash has failed. How can I test that idea? and is there an easy way to access that stupid switch? It looks like a huge pain to get at.
This is my '89 brown crew cab that I use regularly. It's always something, but somehow it's never something good.
Is it a tilt column? If it is, there's a U shaped piece of metal in the key linkage that'll break, you can still key on sometimes but the throw isn't long enough to run the starter.
nelstomlinson
Delta Junction AK
Yes, it is a tilt wheel. Will that u shaped thingy shorten the throw so much that there's nothing happening, as if the key hasn't been turned at all? How do I get at that?
nelstomlinson
Delta Junction AK
The first few seconds of that video show him pushing the rod down with pliers to start the truck. I'll try that in the morning, and if it works, I need to replace that u shaped bit. If it doesn't work, I'll probably need to replace the switch.
Thanks!
Ive replaced three of them in the last ten years.
They aren't expensive and you can still get them from ford.
Cubey
Van dweller
If the rod thing is broken, the ignition switch will feel floppy/loose in rotation.
It could also be your starter relay/solenoid.
If it's automatic transmission, it could be the neutral safety switch. Put in neutral instead of park and try.
I'm thinking it's the battery cables. They'll get nasty corroded in the lead lug and you'll have batteries charged, but the juice don't flow.
nelstomlinson
Delta Junction AK
When I turn the key, nothing happens. It's as if I hadn't turned the key at all. I think that rules out neutral safety switch and starter solenoid.
I'll double check the cables, but I repaired them when I put the engine back in, should still be good a few months later.
Double check that you have power at the start solenoid on the passenger fender. Thats also where are the fusible links are that feed literally everything on the truck
nelstomlinson
Delta Junction AK
Ah, good thought, I hadn't checked there, Nero. This morning I took a pair of pliers to that rod. It does NOT move independently of the key, I cannot push it farther than the key does, and the key does not feel floppy or lose.
I'll check for volts at the starter solenoid, and if none, I'll get an ignition switch on order.
Check fuse 18 under the dash. Should be a 15a fuse, it runs the cluster and stuff.
Vincent
