OldIron82
Hello everyone. 1990 F350 7.3 with a E4OD. This is my first automatic, I’ve always had ZF5’s.
I’ve gone down lots of rabbit holes reading tech articles and other threads and unfortunately I just feel I have to make my own thread to try to get guidance.
1. Here goes. With the selector in DRIVE:
…2nd, 3rd, and 4th… When you let off the throttle, the transmission neutrals out and when you get back on the throttle it reengages at the rpm it was at before you let off.
2. If you are sitting at a stop and get on the throttle and get up to highway speed it will shift flawlessly 1-2-3-4 but once you let off, the engine unhooks and is neutral until you get back on the throttle and bring the RPMs back to where you let off at.
3. Selector in 2: engine stays with transmission no matter what. Selector in 1… engine stays with trans no matter what.
THINGS I KNOW TO BE TRUE:
1.No flashing OD off light.
2.The antilock brake light is on constantly.
3. Switch for brake lights on the brake pedal is screwy. Sometimes the rear lights go on, sometimes they don’t. Always power to one side of the brake pedal switch verified with test light.
4. I do not know the health of the FIPL.
5. I ordered a OBD one scanner to plug into this and I am awaiting its arrival.
That’s all for now. I can tell you the transmission is a Jasper, it still has a serial number sticker on the side of it, but it is older than 10 years because Jasper has no record of that number anymore. The fluid is beautiful at the correct level and it does not smell burned at all. The truck has been off the road for a ridiculous amount of time and was found at a farm and the last inspection was in 2005.
If it is most likely a mechanical problem, I am already at peace with having to tear it out of the truck, but if it is something stupid electrical, which from what I gather on my research very well could be, I’m hoping somebody could point me in the right direction if this issue sounds familiar to them.
Thank you all so much for reading.
