BeastMaster
The problem with a misadjusted FIPL sensor is that it causes the controller to make inappropriate shifts and not set the line pressure accurately, albeit my experience with the controller is that it is pretty good at keeping the mechanicals out of trouble by going into limp-home mode ( flashing OD lamp, really harsh shifts, as it maxxes out hydraulic line pressure ( via EPC solenoid ) trying to avoid slippage ).
Everyone seems to tell me these are pretty robust transmissions, so I wouldn't fret much. From what you have said so far...sounds like just some sensor maintenance is due.
Now, on my van, the FIPL sensor is secured by two 1/4-20 screws having a Torx T-27 head. I do not know if all use this, as I bought my van off Craigslist ten years ago. On the van, the fuel filter is in the way of getting to the adjustment screws. I used a six-inch long Torx bit and a 1/4" flex-head socket wrench to get behind the fuel filter. Adjustment is done by loosening both screws and rotating the assembly.
On my van, my FIPL sensor had a worn spot in it that kept tripping off errors. If you can get an oscilloscope or an old-school mechanical VOM ( Triplett 630, Simpson 260, or similar ), look for smooth voltage changes as the accelerator is operated. The engine need not be running, just key on is sufficient Don't leave the engine in the key-on state without running for a long time, though ( > 10 min or so ), as others here have noted the fuel shutoff solenoid in the injection pump uses incoming fuel flow as a coolant.
