Solid mounts would be an aftermarket design...
Mounts are made by vulcanizing rubber to two pieces of steel, with some sort of a safety bolt or flange to keep the mount from coming completely apart if the rubber bond should fail.
You can tell if they are bad if the rubber is soft from being soaked with oil, or if you jack gently under the motor and you see a gap inside the mounts. I believe it is the drivers' side mount that will normally fail first due to the direction that the motor torques to on acceleration (opposite crankshaft rotation).
