Rob,
I've been reading with great interest about your alt fueled truck. I, too, would like to do something along the same lines. A couple of thigs that I thought of are, why add a second tank selector switch? Could you just wires the 2nd tank selector valve off of the 1st one?
Another thing, where did you mount the second fuel filter and how did you run all of the extra plumbing? I was thinking on my truck, to run the garbage tank fuel through the trans cooler in my radiator. That should warm it to 190' or so. In place of the raditor trans cooler, I was going to install an 18,000 lb trans cooler in front of the radiator. I noticed on your truck its a 5 speed, so it might be cost prohibited to buy a radiator.
Right now, I'm just getting set up to run 2 gallons of waste oil with each fill up. I need to get a filter and some containers to mix it. I could cut my fuel bill by75% or more if I went with your method, though. Where did you get your filters? I'm thinking of stopping by a Tractor Supply store on my way home from work and take a look. Thanks,
John H
