A bit more info for you.
Ken at DPS has milled 120 thou off a set of pistons with the intention of more boost, probably with his twin turbo setup.
The only problems he had was getting it started, even when the temps were warm.
120 thou should drop the compression to somewhere in the 16 to 1 area.
80 thou puts you in the 18 to 1 neighborhood, close to what a Stroke runs in stock form.
I will also say that milling the pistons does drop the bottom end torque a little until the turbo starts spooling.
Not something that you would normally notice, but with the weighs I pull and the terrain I live in, I did notice it when starting out going uphill.
As soon as the turbo starts spooling that torque drop is changed the other direction though.
As for the pipe wrap, while the engine was down I painted everything with ceramic high heat paint.
The crossover pipe, the Y at the rear of the passenger side head and the turbo up pipe are all wrapped with header wrap.
As soon as I installed the wrap I soaked the wrap with high heat ceramic paint by spraying on a very heavy coat of paint, to the point it was about to drip.
I let that set up for several hours in the June sun while working on other things.
Then that evening the parts were dry to the touch, I re wrapped everything with a second layer of wrap.
And once again I applied a very heavy coat of ceramic paint till the wrap was well soaked.
I started with two rolls of wrap, and there was a little left over, so I started about an inch down on the down pipe and went down the pipe till I ran out of wrap, just enough to get below the cab where the down pipe is close to the floorboard.
I also soaked that with ceramic paint till the wrap was very saturated.
I did a low RPM smash the throttle in high gear while pulling a hill a couple weeks ago, as I remember 1200 RPM was where the boost gauge went past 10 PSI, so I can say that keeping as much heat in the exhaust before the turbo did help with low RPM boost since the turbo spools faster.
Running high boost on an IDI does take some extra measures on the exhaust connections between the heads and the turbo and some extra measures on the intake side between the turbo and the heads.
None of those connections were designed to hold pressure when the IDI was developed.
They work rather well until the pressure gets above 20 PSI or so, but above that they will leak.
