It is leaking but I only have to refill every couple months, now I believe this leak is sprayed by the engine fan all over the radiator and as a result it clogging all the fins. I don't like that so I need advice on first how to get rid of this oil/dirt stuff in the rad fins (curiously it only build up on the rad fins but not on the a/c cooler fins), I thought maybe using brake cleaner and then spray with lots of water, will this be the best way?
Also I need to do something about this leak before I clean up everything so, can I rebuild this steering box or should I just get a new one? I hear about the "red box" before but I don't know where to get one and if it need any modifications like using adapter for the steering and hydro-booster hoses.
Thank You for any help.
